Dodge Charger Forum - Forums and Owners Club!
Go Back   Dodge Charger Forum - Forums and Owners Club! > Dodge Charger Forum - Dodge Charger Discussion > 2012 Dodge Charger Forum
Notices
2012 Dodge Charger Forum For Discussion of the 2012 Dodge Charger
Vendor Highlight! - Check these guys out for great deals on Parts and Accessories!
AutoAnything
R1 Concepts
AutoAnything
Reply
Thread Tools
  #1
Old 03-24-2012, 03:13 PM
NorthernLights NorthernLights is offline
Dodge Charger Forum Member
Gender: Male
Vehicle: Charger
Vehicle Year: 7th Gen - 2016
Trim Level: SXT
Rep:50
NorthernLights will become famous soon enough
Default 2012 Oil Change - R/T 5.7 & SVT 3.6
I just changed the oil on both cars and have the following:
R/T with 1700 miles on the odometer - Of course you have to remove the rubber cover from the bottom of the engine which is four small bolts and nothing to it. Drained the oil with no event. But man, that oil filter was on there like it was welded on at the factory so had to buy an oil wrench cap at AutoZone to get it off. I purchase Oil Filter "C" Cap Wrench (http://www.autozone.com/autozone/acc...ier=153159_0_0_) and it took some elbow grease but finally got it to move. Also, be sure to check for the traditional stuck on oil filter gasket as it was stuck to the engine and not to the filter when I removed it. It's been this way for every new Charger I've purchased. Seven quarts 5W20 synthetic and you're back in business.
SXT 3.6L with 700 miles on the odometer - Wow! This was a breeze to change the oil on this baby. Pull the rubber cover on the bottom of the engine, drain the oil completely, then using a 15/16 socket go to the top of the engine and remove the oil filter. Pull the old O ring off the cap and replace it with a slightly oiled new one. Then put the new oil filter on the cap - it only goes on one way and snaps in - then screw it back on. There was no mess and the easiest oil filter I've ever changed. Put the bolt back in the oil pan and then using six quarts of 5W30 synthetic fill it back up again.
With both of them I started it up after the job was done to check for leaks and then replaced the bottom rubber engine cover - torque to 35 foot pounds as per the labeling on the cover.
Without a doubt both were very easy to do and I was amazed in the sunshine all the shiny metal in not only the filters but suspended in the oil.
P.S. We'll be changing out the grill on the R/T tomorrow...getting rid of the factory chrome that came with the car and going with the all black we got from Steve White Motors. Will let you know how pulling the front fascia works out.
__________________
2012 Charger R/T & 2012 Charger SXT Blacktop
Both are Pitch Black and yes, both have the 8.4" screen!
Sponsored links
  #2
Old 03-24-2012, 11:48 PM
Sirhc's Avatar
Sirhc Sirhc is offline
Dodge Charger Forum Senior Member
Gender: Male
Vehicle: 12' Charger R/T
Trim Level: R/T
Color: Tungsten
Rep:213
Sirhc has a spectacular aura aboutSirhc has a spectacular aura aboutSirhc has a spectacular aura about
Default
Quote:
Where was this info a few days ago. I fell victim.
__________________
Corsa Extreme, 2012 Mopar CAI, BT Catch Can, Mopar pedal kit
  #3
Old 03-25-2012, 12:12 AM
burkdadhemi's Avatar
burkdadhemi burkdadhemi is offline
Gender: Male
Vehicle: 06 Charger
Vehicle Year: 6th Gen - 2006
Trim Level: SRT8
Color: Brilliant Black
Rep:17329
burkdadhemi has a reputation beyond reputeburkdadhemi has a reputation beyond reputeburkdadhemi has a reputation beyond reputeburkdadhemi has a reputation beyond reputeburkdadhemi has a reputation beyond reputeburkdadhemi has a reputation beyond reputeburkdadhemi has a reputation beyond reputeburkdadhemi has a reputation beyond reputeburkdadhemi has a reputation beyond reputeburkdadhemi has a reputation beyond reputeburkdadhemi has a reputation beyond repute
Default
Congrats man on your day of being with your babies.
__________________
PWR-Heads/Cam/Intake/87mm TB/No Cats/ Magnaflow Mufflers TruX Pipe, 3" Pipe
]Pedder Drop Springs/Shocks/Bushings
SpeedLogix Rear Adjustable Control Arms
Chubby Sway Bars/Front Strut brace
AIRAID INTAKE
R-1 slotted & Drilled Rotors
  #4
Old 03-25-2012, 03:33 AM
Skyfixer Skyfixer is offline
Gender: Male
Vehicle: Charger R/T
Vehicle Year: 2nd Gen - 2012
Trim Level: R/T
Color: Pitch Black
Rep:165
Skyfixer has a spectacular aura aboutSkyfixer has a spectacular aura about
Default Oil Change
Thanks for the info.
__________________
2012 Pitch Black Dodge Charger R/T
  #5
Old 03-25-2012, 09:26 AM
2Cav's Avatar
2Cav 2Cav is offline
Vehicle: '11' Charger RT
Vehicle Year: 2nd Gen - 2011
Trim Level: R/T
Color: Tungsten
Rep:7387
2Cav has a reputation beyond repute2Cav has a reputation beyond repute2Cav has a reputation beyond repute2Cav has a reputation beyond repute2Cav has a reputation beyond repute2Cav has a reputation beyond repute2Cav has a reputation beyond repute2Cav has a reputation beyond repute2Cav has a reputation beyond repute2Cav has a reputation beyond repute2Cav has a reputation beyond repute
Default
Very good post! reps to you!
Jeff
__________________
-- 2011 Tungsten Charger RT Max, RWD --
Hemi Registry #1672 ~~ Mod list, check out: My Garage
I AM the loose nut between the steering wheel and seat!
  #6
Old 04-05-2012, 09:24 PM
Nobail Nobail is offline
Dodge Charger Forum Newcomer
Vehicle: Charger
Rep:37
Nobail is on a distinguished road
Default
0W-40 is what's recommended for my new 5.7.
  #7
Old 04-05-2012, 10:12 PM
Sirhc's Avatar
Gender: Male
Trim Level: R/T
Color: Tungsten
Rep:213
Default
Quote:
That is for the 6.4L engines, did you see it on a leaflet in your manual? Your 5.7 takes 5W20.
__________________
  #8
Old 04-05-2012, 10:20 PM
Gender: Male
Vehicle: Charger
Trim Level: SXT
Rep:50
Default
I agree 100%...5W20 in the 5.7 per the owners manual.
__________________
  #9
Old 04-05-2012, 10:41 PM
Vehicle: Charger
Rep:37
Default
There's a postcard type insert in the owner's manual which states:
"USER GUIDE ADDENDUM
THIS ADDENDUM UPDATES INFORMATION ABOUT MAINTENANCE PROCEDURES IN SECTION 7 OF YOUR OWNERS MANUAL AND IN MAINTAINING YOUR VEHICLE OF YOUR USER GUIDE
Engine Oil Selection
For best protection and maximum protection under all types of operating conditions, the manufacturer only recommends full synthetic engine oils that meet the American Petroleum Institute (API) categories of SM or SM/CF
The manufacturer recommends the use of a full synthetic SAE 0W-40 engine oil or equivalent.
  #10
Old 04-06-2012, 07:24 AM
JohnsonCA's Avatar
JohnsonCA JohnsonCA is offline
Charger ForumZ Supporter
Gender: Male
Vehicle: Charger R/T MAX
Trim Level: R/T
Color: Pitch Black
Rep:238
JohnsonCA has a spectacular aura aboutJohnsonCA has a spectacular aura aboutJohnsonCA has a spectacular aura about
Default
You'll also notice on the bottom corner that it says SRT8. Can you please check your yellow card again?
__________________
Powdercoated R/T MAX rims black & replaced Dodge caps with Mopar caps, replaced chrome trim in front grill with black, replaced Dodge emblem with Mopar emblem in front grill, 35% tint, 2 layers Stinger Roadkill noise damping all four doors and trunk, clear bra front bumper & side mirrors, lockpick C8, 2 coats Ziebart undercarriage rust and soundbarrier
Reply
Bookmarks
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
2012 Charger info and options ChargerRT904 2011 Dodge Charger Forum 16 08-25-2011 09:13 AM
Left Lane & Jack Baruth freaking love the 2012 Charger SRT-8 steveua 2011 Dodge Charger Forum 6 07-19-2011 07:30 AM
Policy change benefits disabled Airmen! SRTAndy Military 3 09-04-2009 05:19 PM
1st Oil Change and a couple of questions. Dont Hurt Me Oil Change - Lubrication - Fluids 18 02-21-2009 06:21 PM
My $400 Oil Change Black07SRT8 6th Gen Dodge Charger 15 10-12-2008 05:14 PM
» Advertisement
= Copyright Chargerforumz.com a GigaThreads.com Network Site =Ad Management by RedTyger
Powered by vBulletin® Version 3.8.10 Beta 1
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
vB.Sponsors
